Searching for clutch slippage there are several suggestions to prevent. New parts, sanding off glaze, shims.
Since I’ve never broken that engine case side, I’m looking for a procedure to break down and reassemble the clutch on my 1100. Is the one out there?
thanks Jeff
thanks Jeff
,,,do remember that Barnett springs were great, better than factory,,,stiffer but great feel,,,,also new plates are best,,,not expensive but you can measure the thickness of the old plates first and sand them and if within spec they should be ok. I tried the extra plate but it was waaaaay too stiff and didnt allow much adjustment and grabbed way too quick. You might try just adjusting the clutch first at the handle and down inside the clutch case and that could be an easy fix, these clutches last a llooooon g time unless hot rodded to death.....keep us inforned,, Mike in S.Diego and Pa
