Replacing O-rings on clutch damper housing?
  • dpo
    • Nov 2013
    • 7
    • Phoenix AZ
    I need to replace the O-rings on the housing of the primary shaft damper- O ring is Yamaha part # 93210-60538-00 O-RING
    Bike is a 1982 XJ1100
    Is there anything I need to give closer attention to or avoid doing? What keeps the shaft from dropping out of position or sliding out when removing the housing?
    I certainly cannot see this housing, and its bearing inside, being screwed on with three small allen head bolts being the only support for the primary shaft and its chain sending power to the tranny.
    The housing and its Orings are seen here: https://www.ebay.com/itm/80-81-YAMAH...LH_TitleDesc=0
    Any help is appreciated
    82 XJ11
    • 2162
    No worries
    I took that part off to polish it on both of my XS11 bikes.
    I broke the first one trying to get it off and had to buy another on eBay. No problem on the second one.
    Th answer to your question is: "Don't worry about it. You can take that part off and put it back on with no trouble."
    BTW: The load is not carried by the bolts. The cylindrical shape of the housing (where the o-ring is) fits snugly inside the case to provide the support. The 3 bolts just hold it onto the case.
