Bike is an 80 xs11, Building this for a cross country tour. Solid good even compression Good light tan color on plugs with stock pipe and air box
The bike has been out fitted with a Supertrap 4-1 and individual air filters cheep ones not K&N.
Started this tune with carb body's cleaned with aerosol auto cleaner and compressed air. All jets pilot, needle and mains were soaked over night,and all passages ware blown clear. Floats set to factory spects.
Started with with 45 pilots and 145 mains which is what I did years ago on two other 11's i had although they were a 78-79 models.
That was about all I Did on the early Bikes, Its not working on this one.
Ihave a good idle at 1000rpm with 47.5 pilots and the idle air screws out 2.5 turns Ive let it idle 15 mins with good lite tan color on all plugs. lite popping on accellerationup to 3000 rpm At 1/4 throttle.
Then as the throttle is opened it falls on its face misfiring at exhaust on a test ride opening the choke had no effect. Have tried this with test with 145's- 135's and now even with the stock jets What do I do nextGuys? MAB.
