server issues
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    server issues
    Anyone besides me having trouble sometimes getting on this site or even when switching threads having the browser time out and saying not found, I troubleshoot from my end and got a no contact from DNL server, I've logged onto several other forums regularly with no issues.
    81 XS1100H
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    Yep, last night I had the same problem. Seems OK this morning. CZ
    • DeanR
      • Jan 2005
      • 1499
      • Finger Lakes NY
      Been happening to me a lot.
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
      • old_skool
        • Nov 2011
        • 554
        • Ohio
        Getting really annoying having so much trouble with the ability to use the server as it constantly times out, is it only me, or is it still having issues with everyone. Didn't know if i should check with my ISP, but I don't have any issues anywhere else. Running a pretty new built puter with Win 7.
        Here's what I see more than the forum--->
        Oh, and DEANR....I'm RDEAN...lol
        81 XS1100H
        • DeanR
          • Jan 2005
          • 1499
          • Finger Lakes NY
          Happening to me frequently. It's a pain... I use Firefox.
          edit : Just realized I already posted, looks like I can't delete this one?
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            Ok guys. This is a problem that has been going on for quite some time. It's because the DNS servers at the host where the site is hosted are pretty much either way overloaded or something. The answer is pretty easy, you need to adjust your hosts file and put the IP address of the server in there and the problem will magically go away. I've added a picture below that shows where the hosts file is, and what the line for the site needs to be. You will most likely need to change the file permissions on the hosts file to give users rights to edit the file before you change it.
            • old_skool
              • Nov 2011
              • 554
              • Ohio
              Made the change, we'll see how it goes. Thanks!
              81 XS1100H
                Hey Skool,
                Cy knows his internet stuff for sure. A little experiment you can do to see if there are any links that are really slowing your access down is to run a Tracert to the site.
                Open a dos box, they type the following command, it will output the results to a text file.
                tracert www.xs11.com >trace.txt
                and hit return...btw there are spaces after tracert and before the >trace.txt.
                Give it a little time, usually 30 to 60 seconds, and then you'll see the prompt show again blinking, then find the "trace.txt" file, and review it. It will look something like this:
                Tracing route to www.xs11.com [64.119.182.118]
                over a maximum of 30 hops:
                1 1 ms 2 ms <1 ms Wireless_Broadband_Router.home [192.168.1.1]
                2 8 ms 9 ms 9 ms L100.NRFLVA-VFTTP-23.verizon-gni.net [96.249.246.1]
                3 11 ms 10 ms 8 ms G0-2-3-7.NRFLVA-LCR-21.verizon-gni.net [130.81.137.244]
                4 21 ms 19 ms 19 ms so-0-0-0-0.LCC1-RES-BB-RTR1-RE1.verizon-gni.net [130.81.22.40]
                5 20 ms 18 ms 19 ms 0.ae1.BR1.IAD8.ALTER.NET [152.63.32.141]
                6 25 ms 18 ms 19 ms ae17.edge1.washingtondc12.level3.net [4.68.62.137]
                7 24 ms 19 ms 18 ms vl-3604-ve-228.ebr2.Washington12.Level3.net [4.69.158.46]
                8 72 ms 72 ms 83 ms vb6.rar3.chicago-il.us.xo.net [207.88.12.33]
                9 35 ms 38 ms 38 ms ae-1-100.ebr1.Chicago2.Level3.net [4.69.132.113]
                10 68 ms 68 ms 68 ms ae-3-3.ebr2.Denver1.Level3.net [4.69.132.61]
                11 385 ms 1205 ms 69 ms ae-21-52.car1.Denver1.Level3.net [4.69.147.99]
                12 92 ms 97 ms 98 ms DATA393-HOLDINGS.car1.Denver1.Level3.net [4.53.14.90]
                13 97 ms 100 ms 97 ms 208-42-224-173.static.data393.net [208.42.224.173]
                14 98 ms 96 ms 98 ms v12.colo.data393.net [208.42.224.46]
                15 97 ms 100 ms 97 ms www.xs11.com [64.119.182.118]
                Trace complete.
                I'm on verizon now, used to be on Cox. Doing this just now, I noticed that there is a fairly long delay at the 11th hop, not sure what it all means for sure, Cy could probably tell, but it's close to the hosting site, and I remember when I would loose access that it was at or near a the similar hop point in Denver!?
                • old_skool
                  • Nov 2011
                  • 554
                  • Ohio
                  Since I made the mod, About a 85-90 % improvement. Maybe once every 30 times, might time out, but not near what it used too, I can live with it now.
                  81 XS1100H
                    • 8055
                    I was able to open the windows pictured, but beyond that, I'm clueless. I don't know how to continue.
                    Does it matter that I continuously move? (hotel to hotel)
                    • old_skool
                      • Nov 2011
                      • 554
                      • Ohio
                      pm sent........
                      81 XS1100H
                        • 8055
                        OK. He fixed it. Thanx guys!
                        Marty (in Germany)
                        • old_skool
                          • Nov 2011
                          • 554
                          • Ohio
                          PROBLEM SOLVED
                          81 XS1100H
                          • DeanR
                            • Jan 2005
                            • 1499
                            • Finger Lakes NY
                            This is the only website/forum that ever gives me a can't find server message. We shouldn't have to delve into our computers to remedy it. Should be taken care of on the other end.
                            80 SG
                            81 SH in parts
                            99 ST1100
                            91 ST1100
                            • old_skool
                              • Nov 2011
                              • 554
                              • Ohio
                              Maybe so, but if you need help, I can talk you through it.
                              81 XS1100H
