error message
  • dpotter58
    • Aug 2004
    • 1846
    • Southern Maryland
    error message
    I dont have any saved messages but get this when trying to pm kboehringer
    What's up ?
    1980 LG
    1981 LH
    • 2046
    Kurt accepts my messages .
    If your mailbox here appears empty, maybe you could try going back to ".com" and emptying your mailbox? Probably a stupid idea, but JAT.
    • dansmith65
      • Aug 2017
      • 138
      • Kootenays, BC , Canada
      I dont have any saved messages...
      Check all folders, including Sent Items.
      80 SG Canada
      • dpotter58
        • Aug 2004
        • 1846
        • Southern Maryland
        Nothing there. I delete all the time. Only one message in my in box. Thats it on
        1980 LG
        1981 LH
        • nezzer
          • Feb 2006
          • 145
          • Denver, CO
          dpotter58 , I checked and the site says you have 242 messages in your sent box, 9 in trash, and 3 in your inbox. An admin can delete all your private messages, but that is as granular as it gets. Do you want all your messages to be deleted, which would presumably include those 3 in your inbox?
          '80 XS Special
          JonathanKnez@hotmail.com
          • dansmith65
            • Aug 2017
            • 138
            nezzer before deleting messages, we should check and see if this is an issue that came from the upgrade, which is also affecting other users. My account's private message count seems correct, though, so I'm not sure what else to check.
            80 SG Canada
            • dpotter58
              • Aug 2004
              • 1846
              • Southern Maryland
              crazy. There were messages there from 2005. I delete on a regular basis, even the sents....
              1980 LG
              1981 LH
              • nezzer
                • Feb 2006
                • 145
                • Denver, CO
                dpotter58, did you find messages in your sent box and delete them? Are you now able to send messages? I still show 250 messages in your sent box. I want to make sure you get squared away in case as Dan said, this is a problem we might see on more user accounts.
                '80 XS Special
                • dpotter58
                  • Aug 2004
                  • 1846
                  • Southern Maryland
                  I did. not sure why you still see them. I just looked and nothing there.
                  1980 LG
                  1981 LH
                  • Rasputin
                    • 3189
                    • Lacombe, Alberta, Canada
                    Wondering if this issue has been resolved.
                    2-79 XS1100 SF
                    2-78 XS1100 E Best bike Ever
                    • dpotter58
                      • Aug 2004
                      • 1846
                      • Southern Maryland
                      I just sent a message and it went!
                      1980 LG
                      1981 LH
                      • nezzer
                        • Feb 2006
                        • 145
                        • Denver, CO
                        I checked your private message statistics and I now only see a count of 2 messages in your sent folder. Looks like clearing out your sent items worked, even if it took a little while for the numbers to show up correctly on the admin page.
                        '80 XS Special
                          • 8756
                          Nezzer, I am having the same problem, I deleted all my old messages and I still get an error message saying I have 350 messages and to delete them. Please help, thanks.
                            • 8756
                            OK, I figured it out. Apparently after deleting messages, they go into another folder and they need to be deleted a second time. Once those were deleted again, all is good.
                              Sorry I'm late to this party, been at hospital with SWMBO getting tests. Yes the database copied ALL msgs from the old site from the time you registered! I had msgs from 2002 to present, a few thousand, took quite a while to delete page by page worth, could not select ALL. Then like Phil said, you have to then flush them again from your deleted folder after removing from your sent folder.
