Video Test
    Also, if turning the bars lock to lock is enough pull on the wires to pull them apart then you need to do some re-routing of the wires. All that will happen now is that the wires will get pulled out of the connector.
      • 2100
      Originally posted by rdmcguy
      I have a few connectors that no longer have the locking tabs
      You might consider using small cable ties instead
      they don't conduct electricity
      Yes, point taken, but I only had 3/16 and wider cable ties. I'm anxious to test ride Her and I'll switch the wire ties for cable ties when I pull the Pacifico for paint.
      Nate, I did just that.
      Thanxs Guys
      Today I was able to check plug color, colortune, resynch, tune by ear, resynch, tune by ear again, check synch and call it good enough to reassemble.
      Hopefully I'll get to test ride before any white stuff falls
      Did the videos work, for you guys, alright ?
      Any tips to make them better will be well received.
