Carb problems
  • drathmann
    • Apr 2016
    • 11
    • Huntsville, AL.
    Carb problems
    Just bought a 79 xs11s, ran awesome on the test ride and then about 100 miles later carb 1 and 2 began flooding. Long story short, one of the pegs on each carb that hold the pin that holds the float in place is broken off. Guess the jb weld the seller used lasted 100 miles or so. Any ideas on a fix that doesn't entail buying carbs? Not really in the budget right now
    79 SF
    There IS a posted correct repair thread posted......maybe in the repair section.....or maybe someone will jump in here with the link for that.
    • Rasputin
      • 3189
      • Lacombe, Alberta, Canada
      Yup that JB weld stuff does not hold up inside carbs. I have just recently (2 days ago) been successful in using the HTS-2000 aluminum repair kit on a set of mine. It took a lot more heat than originally thought to do the job but it will work.
      There is a thread on carb float post repair on here for sure and it may be down in the maintenance or repair sections but it is available on the site. I am searching other stuff or I would look it up for you. Good practice to search the site and the use of google with xs11 in the search terms is a shortcut. Have fun.
      2-79 XS1100 SF
      2-78 XS1100 E Best bike Ever
        • 1566
        Here's a thread from a few years ago.
        • drathmann
          • Apr 2016
          • 11
          • Huntsville, AL.
          Thanks very much for the info!very nice how helpful everyone is on here
          79 SF
            • 723
            Here is my totally unorthodox post repair method.
            I simply cut off a brass rifle casing and a little snipping and drilling and then slipped it over top of the broken post stud. Looks weird for sure but it works!
            • TallBob
              • Sep 2011
              • 160
              • Greensburg, PENN.
              Thats a interesting way of fixing the broken float post problem. What caliber shell did you end up using? Thanks
                • 723
                TallBob,
                After quite a bit of experimental trial and error with the various brass shell casings that I had laying around here, I settled on .222 Remington.
                I have pictures of the process if anyone is interested.
                • drathmann
                  • Apr 2016
                  • 11
                  • Huntsville, AL.
                  Would be cool to see the process for sure. I checked out the pics of your bikes, way cool btw
                  79 SF
                    • 723
                    Thanks Drathmann.
                    Here ya go:
                    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
