Garage Cleaning
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    Garage Cleaning
    I have a bunch of stuff that came off the parts bike that had a bad frame and a frozen motor, and other odds and ends I won't be needing. Most of the stuff I have no idea what I should ask, so shoot me an offer, and I'll only add what shipping is. I'll do my best to find the least expensive shipping.
    0-80 standard speedo
    frt &rear calipers- as is, need cleaning up
    igniter unit from an 81 standard
    stock Yamaha oil cooler- has the adapter plate, bolt, filter bowl, and housing bolt
    XJ handlebars and top triple tree clamp
    security chain and box - sort of like a bicycle lock
    frt M/C - resevoir is rough
    standard seat cowling - bottom holes are cracked
    80/81 carb bodies
    rear shocks - not great, but usable
    2 special handlebars
    misc electrical stuff
    complete set of drilled brake discs - 5/16 holes in a swirl pattern
    4 brass carb floats
    I have probably left out some things. Please PM me, it's easier that way.
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
  • Big Beadle
    • Jul 2011
    • 22
    • Queensbury, NY
    clean garage
    How much for the the rotors each and all 3, I really only need the rear one
    79 XS11 SPECIAL Best $200$ ever spent
    4-1 kirker Header
    K&N air PODS
    Accel 8.8mm wires & E3 spark plugs
    T.C's. SOFA
    FD swap
    XJ AIR RIDE
    SS Brake lines
    100w halogen running lights
    ALL BALLS Bearings=ALL
    147.5 mains 2 out on the screws
    Fuse box updated 90*flag spades
    http://www.photoreflect.com/pr3/Orde...&po=157&pc=456
    • Toolmaker Tim
      • 671
      Brake discs
      I don't want to break them up because the holes were drilled in a CNC mill and they all match. Say $50+shipping for all three?
      1979XS1100SF
      Jardine 4in1
      Dunlop Elite 3's
      142.5 main jets
      45 pilot jets
      750/850 FD mod.
      XV 920 Needle Mod.
      • Big Beadle
        • Jul 2011
        • 22
        • Queensbury, NY
        drilled rotors
        Ill Take-em this Friday if you can set-em aside till then, we can figure out payment and all that good stuff, if ya want send me a PM and we can go from there, thanks....BB
        4-1 kirker Header
        K&N air PODS
        T.C's. SOFA
        FD swap
        XJ AIR RIDE
        SS Brake lines
        • Toolmaker Tim
          • 671
          Parts
          Brake discs are sold pending payment
          1979XS1100SF
          Jardine 4in1
          Dunlop Elite 3's
          142.5 main jets
          45 pilot jets
          750/850 FD mod.
          XV 920 Needle Mod.
          • Toolmaker Tim
            • 671
            Intake Boots
            I also have 4 intake boots, the ones that go between the carbs and the motor. They are slightly cracked on the outside, but good on the inside. Make me an offer.
            1979XS1100SF
            Jardine 4in1
            Dunlop Elite 3's
            142.5 main jets
            45 pilot jets
            750/850 FD mod.
            XV 920 Needle Mod.
            • Toolmaker Tim
              • 671
              Intakes
              Intakes sold pending payment
              1979XS1100SF
              Jardine 4in1
              Dunlop Elite 3's
              142.5 main jets
              45 pilot jets
              750/850 FD mod.
              XV 920 Needle Mod.
              • pase
                • Nov 2010
                • 33
                • Conyers, Ga.
                Hey man do you have the motor
                • Toolmaker Tim
                  • 671
                  Dead Motor
                  I do have the motor off the parts bike, but it's a goner. The pistons are stuck solid in the cylinders. I found what sort of looked like a mouse skeleton in cylinder #3. I'm guessing the bike sat in the open with the plugs out of it. There are some parts that are ok, like the head, the middle drive, and anything that had a coat of oil to protect it. Right now I am taking it apart to see what is still usable.
                  1979XS1100SF
                  Jardine 4in1
                  Dunlop Elite 3's
                  142.5 main jets
                  45 pilot jets
                  750/850 FD mod.
                  XV 920 Needle Mod.
                  • Toolmaker Tim
                    • 671
                    Some More Stuff
                    Cast grab bar
                    Chrome engine guards - stock
                    2 sets buckhorn (Special) handlebars
                    middle drive
                    81 final drive
                    80/81 head - complete
                    80/81 intake & exhaust cams
                    complete set of valve buckets
                    handlebar controls for both sides - rough
                    various electrical parts
                    steel clutch discs for the add a disc mod
                    If there is anything else anybody might need let me know and I'll check. As before, shoot me an offer, I'll add shipping and we will go from there.
                    1979XS1100SF
                    Jardine 4in1
                    Dunlop Elite 3's
                    142.5 main jets
                    45 pilot jets
                    750/850 FD mod.
                    XV 920 Needle Mod.
                    • latexeses
                      • Jun 2008
                      • 1491
                      • California
                      Tim,
                      Sent you a PM.
                      Rodger
                      Everything on hold...
                      • XSTrey11
                        • May 2011
                        • 111
                        • Carbondale, Illinois
                        Seat Cowling
                        Would you be able to PM me a picture of the seat cowling? Thanks.
                        1980 XS11G 22XXX miles.
                        • neJeff
                          • Jun 2011
                          • 346
                          • Nebraska
                          Pm sent, thanks
                          Current Daily Rides / Projects
                          1979 Yamaha XS1100F (since 2015)...Project
                          1980 Suzuki GS850G (since 2012)
                          1979 Kawasaki KZ400B (since 2013)
                          • Toolmaker Tim
                            • 671
                            Parts that are sold
                            The discs and the intake boots are sold. The TCI and floats are sold pending payment.
                            1979XS1100SF
                            Jardine 4in1
                            Dunlop Elite 3's
                            142.5 main jets
                            45 pilot jets
                            750/850 FD mod.
                            XV 920 Needle Mod.
                            • Toolmaker Tim
                              • 671
                              The TCI and the floats are sold.
                              1979XS1100SF
                              Jardine 4in1
                              Dunlop Elite 3's
                              142.5 main jets
                              45 pilot jets
                              750/850 FD mod.
                              XV 920 Needle Mod.
