Venturer
76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'e -
I'm sure the SG seat will work on the H, but I wouldn't go so far as to call it "plug-n-play".Plug-n-play on the Venturer. Cushion will 'ride-up' a bit on tank(no mods needed). Where the sides of seat slope, that lowest part will hit top close enough to sidecovers that seat has to be removed to remove sidecovers. BTW, the Venturer is the ONLY Standard model a Special set WILL fit on
Simply having to remove the seat to get the sidecovers off would negate the SG seat being a "plug-n-play" mod on the H.
And even though you may not have to trim the seat pan in the front, I probably would ... just to make it look and fit better.
And then there's still the problem of that gaping hole in the back of the SG seat where the taillight fits ... that would be a deal-breaker for me ... it just wouldn't look right.
Actually, the '79SF seat would probably be a better fit on the H. The SF seat doesn't extend back quite as far as the H seat ...
But the lower edge of the SF seat doesn't extend down as far as the SG seat, which would hopefully eliminate the sidecover problem. And the SF seat doesn't have the gaping hole in the back.
Pretty sure you would have to swap the inner fender, though ... in order to slightly relocate the TCI.
Also, someone CMIIW, but based on what I've learned, you can fit a '79 Special seat onto an '80 Standard (with the inner fender swap), because the '80-'81 Standard pans are the same.
1979 Honda CBX
2002 Kawasaki ZRX1200R
WE MISS YOU, DONComment
Marco,
You put one of those tool bags at the back of the seat and it looks like it was made that way.Marty (in Mississippi)
XS650EComment
How could you tell ?I think this is a 78-79 STD in PA.
http://motorcycles.smartcarguide.com/listing/46284258/
.........with an 81' motor
.76 XS650 C ROADSTER
80 XS 1100 SG
AKA; Don'e, UD, Unca Don'eComment
1979 Honda CBX
