1979 SF in Denver
  • Prisoner6
    • Aug 2013
    • 1184
    • Phoenix, AZ
    1979 SF in Denver
    Seller is asking $3,500 OBO ...
    18K miles ... What do you think?
    P.S. Wondering why left petcock is on Prime, while right petcock is Off ...
    Marco
    1979 Honda CBX
    2002 Kawasaki ZRX1200R
    WE MISS YOU, DON
    • 8011
    It's a nice looking bike!
    The engine appears to be from a later model.
    • Prisoner6
      • Aug 2013
      • 1184
      • Phoenix, AZ
      I was wondering about that, too, after looking at the area where the kick-starter shaft should be on a '79 SF ...
      Marco
      1979 Honda CBX
      WE MISS YOU, DON
        • 8011
        For $3500, I want new footrest covers!
        1J7-27413-01-00 COVER, FOOTREST $18.46 2
        • MPittma100
          • Aug 2011
          • 2359
          1979sf
          Nice looker. Not being totally stock does damage to the $3500 asking price regardless of the said mileage.
          MP
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
            • 3932
            I fancy the color
              • 3255
              And the fancy color isn't stock either... Good observation on the kickstarter being in absentia... What about "very little rust" in reference to the tank? It oughta be pristine for that $$.
              What about all the stuff you can't see? Brake calipers/pistons/fluid, master cylinders front/rear, brake pads, brake line condition, when were carbs last gone through, are the carbs from a 79 or a later model (will dictate what kind of rebuild kit, and thus cost, you may have), are petcocks solid and octy diaphragm working, fork fluid changed, steering head and swing arm bearings serviced, throttle/clutch/speedo cables cleaned and lubed, does tach needle wobble, when were valves adjusted, last disassembly to lube drive shaft splines that don't get lube from the zerk, lighting reserve unit working, cam chain adjuster isn'tmaxed out, when was it adjusted last, and cam chain is in good shape despite low miles (if oil wasnt changed for an extended interval at some point, it can cause premature wear/stretch) tires not old and hard? Bike hasn't seen much use and that can be as hard on a bike as running it hard and hanging it up wet. I don't see anything mentioned about a service manual, and doesn't appear to be anyone from the forum.
              Whew...did I forget anything?
              I bought a project 80G and every last thing on the list above, and probably a few more I forgot needed going through.
              It has good curb appeal, but we should all be alert to "what lies beneath".
              ZRX1200
              Seca 750
                • 3932
                Geeze Bonz, way to be a Debbie Downer. Can't it just be an expensive sexy bike to look at? Lol, jk. You're right about all of that obviously. I just like it cuz it's the same color as mine.
                • DCII
                  • Jul 2010
                  • 792
                  • Centerville, Ohio
                  Bonz, you overlooked the missing plastic insert that goes in the filler plug on the rear drive housing.
                  • Prisoner6
                    • Aug 2013
                    • 1184
                    • Phoenix, AZ
                    ... when were carbs last gone through, are the carbs from a 79 or a later model (will dictate what kind of rebuild kit, and thus cost, you may have)
                    Yeah, that "very little if any rust" comment made me a little suspicious, too.
                    As for the carbs ... of course we can't see carbs 2 and 3, but based on the photos, it appears to have the "early" 78/79 carbs.
                    Marco
                    1979 Honda CBX
                    WE MISS YOU, DON
                      • 8011
                      The reported mileage means nothing. Especially assuming the engine serial number is not going to be a match. The yellow is an attention grabber.
                      • Prisoner6
                        • Aug 2013
                        • 1184
                        • Phoenix, AZ
                        I fancy the color
                        I thought you would like that COLOR, Ian ...
                        I went to high school with a girl named Debbie Downer ... seriously ... I'm not kidding ...
                        Marco
                        1979 Honda CBX
                        WE MISS YOU, DON
                          • 3255
                          I live within a couple hours of that bike... I like the yellow as well!
                          ZRX1200
                          Seca 750
                          • rdmcguy
                            • Jul 2013
                            • 515
                            • Denver, Colo.
                            A little pricy
                            That bike is about an hour east of Denver more of a rural setting out there.
                            I think When I first noticed it the price was 4,000 The price seems high to me unless it has been refurbished somewhat recently.
                            As Bonz mentioned they are still 30+ year old parts whether lightly used or not!
                            • DCII
                              • Jul 2010
                              • 792
                              • Centerville, Ohio
                              I think the only thing you can be sure has 18k miles on it is the speedometer . The yellow color does look sharp on the bike, the question I would ask is what went wrong with the original motor with that few miles on it.
