79 special
  • rdmcguy
    • Jul 2013
    • 515
    • Denver, Colo.
    79 special
    A 79 special in Phoenix on craigslist,
    $300.....Doesn't look too bad!
    Parts if nothing else.
  • Prisoner6
    • Aug 2013
    • 1184
    • Phoenix, AZ
    Here it is:
    Marco
    1979 Honda CBX
    2002 Kawasaki ZRX1200R
    WE MISS YOU, DON
      • 2101
      So which one of you guys is gonna steal this one ?
        Right in my price range, but WAY to far away. Probably a lot more work than meets the eye to get it running and ready for miles of smiles. But it does look complete, save the busted stuff he mentioned.
          • 8073
          Busted stuff he mentioned is readily available. Mike's XS has the headlight ring and signals.
            • 6765
            a little TLC and this bike would clean up well...
            2005 Honda SilverWing 600
            2018 Honda PC-Xpress 150
              Its usually the hidden stuff like frame rust, cracked rotors, torn up filters, missing oil filter spring or washer, did I mention rusty stuff?.
              I have yet to need a part I can not find at all. It is how much the part cost you that hits hard at times. And the clean up that leads to re finishing what initially looked decent parts that takes alot of time and effort.
                • 4008
                Hey Don- Just curious, any part you've had to buy that made u cringe? I guess I'm feeling pretty good sitting on an extra bike's worth of parts, plus parts from my 750's/850. Just no spare engine.
                  • 6765
                  rust? The bike is in Arizona... more like dust...other defects possibly...
                  • TomB
                    • Aug 2006
                    • 967
                    • Cumbria, UK
                    Just curious, what does that washer and spring actually do?
                    Tom
                    • rdmcguy
                      • Jul 2013
                      • 515
                      • Denver, Colo.
                      spring and washer
                      As far as I have been lead to believe the spring and washer push the filter
                      towards the cases in order for the oil to be filtered as it enters/exits versus the filter just kind of flopping around in there.
                      As for rust on bikes from that part of the country,I just picked up two in New mexico and can say there is very little rust as some one here mentioned
                      Yes there is dust ,very fine dust as a matter of fact, found quite a bit in electrical connectors, also noticed that where there was a little oil or grease
                      the dust was almost a preservative, wiped right off nice and clean below
                      I'm sure there are exceptions but that has been my experience.
                        • 8073
                        It's the rubber and plastic that takes a beating in the sun. Exposed wiring insulation could be suspect as well.
