crankcase oil plug
crankcase oil plug
USMC 2005 - Present
79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!Tags: None
For your information, that is NOT the crankcase oil drain and should NEVER be removed! Crankcase oil drain plug is on bottomside just behind the oil filter housing.............you need to seriously read up on these ole' 1100 scoots before you continue to keep making BAD mistakes as you've already done!81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by motoman View PostFor your information, that is NOT the crankcase oil drain and should NEVER be removed! Crankcase oil drain plug is on bottomside just behind the oil filter housing.............you need to seriously read up on these ole' 1100 scoots before you continue to keep making BAD mistakes as you've already done!
Thanks again for your opinion.USMC 2005 - Present
P.M. sent...Ty
78 XS1100E - Now in Minnesota
80 XS1100LG - The Punisher
82 XJ1100 - Daughter's Bike
Found the lower case and was able to remove the bolt. I will get you the shipping price in the morning.
By the way your PM box is full...Ty
