transmission bolt
  • Hmar
    • Jun 2011
    • 100
    • Springfield. MA
    transmission bolt
    Looking for the transmission shaft bolt for 81 special. Here is what is left of mine for reference:
    Yamaha part number is:
    90105-10085-00
    I need the washer, too.
    Thanks
    1981 XS 11 special
    red
    40,000 miles
    H'mar,
    I think I have a spare two-step bolt for the late-model XS and XJ,
    Send me a PM.
    • Rasputin
      • 3177
      • Lacombe, Alberta, Canada
      If no one else can help out I can hook you up with used or brand new. I have a couple of used ones around here for sure. The new one is in my private stock and is dear to me, so do not let shiny get in the way of a good deal.
      2-79 XS1100 SF
      2-78 XS1100 E Best bike Ever
        The washer I have is 2.90 mm, slightly less than 1/8 in. The washers should all be pretty close to the same size:-
          • 9980
          When you put it back in use some Loctite on it. Be sure the teeth on the clutch pack aren't damaged.
            Don't remember when they changed, but not all years used that washer.
            I see one on Ebay for another option. http://www.ebay.com/itm/YAMAHA-NOS-X...b470f3&vxp=mtr
              Welcome back!
                • 9980
                IIRC it was 80.
                  Originally posted by BA80
                  IIRC it was 80.
                  I only have two '80G engines to check:
                  With the double-row bearing: 3H5-000758
                  With the single-row bearing: 3H5-005193
                  The broken '82 XJ11 engine had the single-row bearing with a two-step bolt and washer that cleaned up good for their measurements and pictures.
                  I wonder if I can fit the earlier lower case with the double-row bearing to my later case with the single-row. There are no serial numbers on the lowers, they're both aluminum color and one of them is getting new paint.
                  Sorry, H'mar, I didn't mean to gleep your thread! The bolt and washer are on the way after I finish making a parts and supplies list to pick up while I'm out and about.
                    • 8628
                    I just changed a couple of pulleys on a Chrysler 3.3 and it used what appears to be the same bolt as our obsolete transmission countershaft bolt. Anyone know the thread pitch and length of the Yamaha bolt?
                      • 8628
                      Here's some pics, these bolts are M10X1.5X30 9.6 strength rating....
                        Close but too long and wrong pitch:
                        M10x25mm 1.25p
                        Strength Rating -- very strong but not as strong as clutch hub gears.
                          • 8628
                          Ah, ok Scott, thanks for checking that.
                            No problem, thanks for looking up those bolts, good memory. I was pretty jazzed when I saw your post and I have the bolt assembly out on the bench while I work on the gear stack so....
                            You could cut the 30mm bolt down to 25mm but changing the pitch wouldn't work. Bummer.
