Need carbs
  • Jeffintampa
    • Apr 2011
    • 344
    • Zephyrhills, Florida
    Need carbs
    Hi need carbs for a 1980 xs1100 sg
    Bike History:1980 XS 1100 special current bike
    1980 XS 850 special wife sold
  • tcoop
    • Nov 2009
    • 793
    • South Weber, UT
    I have a set. Let me take a look at them to make sure they are complete and I'll let you know.
    Ty
    78 XS1100E - Now in Minnesota
    80 XS1100LG - The Punisher
    82 XJ1100 - Daughter's Bike
    • Jeffintampa
      • Apr 2011
      • 344
      Thank you may be better than trying to fix my broken post.
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        Might be an idea ? Post which carb has the broken post ! I think there might be a few on here that have a stash of carbs and parts ? ? ?
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
        • Rasputin
          • 3189
          • Lacombe, Alberta, Canada
          You are right Done. I probably have 15 or more carb bodies laying around here. So should many other members. Depending on which carb year and position a person needed, it may be easier and cheaper to replace the buggered carb.
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
          • Jeffintampa
            • Apr 2011
            • 344
            the broken post is on 2
            • Jeffintampa
              • Apr 2011
              • 344
              these carbs
              Number 2
              [IMG][/IMG]
              • tcoop
                • Nov 2009
                • 793
                • South Weber, UT
                Jeff, these are the carbs that I have. the arm to pull out the choke is broken and the detente balls are missing (the ones that hold the choke in position). The only reason that I did not use these is i could not get them to stop leaking...but I had other sets of carbs so I didn't try very hard.
                A cheaper rout would be to get the carb body that you need and swap it in. If this is the direction you want to go send me a pm we can work out what you need.
                Ty
                • Donmystic1
                  • Jun 2014
                  • 185
                  • Mystic, CT
                  csrbs
                  I have a set ready to go.they will need snyc when installed.
                  Don
                  860 460 3282
                  78E, 79F, 80G
                  • Jeffintampa
                    • Apr 2011
                    • 344
                    See if I can get a 2
                    I just dropped 20 sending my carbs to Schmitt in Pa so gonna try to find just a single #2 from an 80 SG and see if I can have it mailed to him
                    • Rasputin
                      • 3189
                      Well those being the later carbs puts me out of donating a #2. All of my spare carb bodies are older style. I have three full sets of the newer ones that are as yet untested and one set that are off a suzuki but is basically (but not exactly), the same body. If someone knew for sure they would work I would break them down as #3 of the air/idle screws is stripped and I am not sure if it will come out.
                      I counted them and I have 24 carb bodies sitting around here. Some of them have a stuck jet or a broken off idle screw, but I have given up on only one of them.
                      Patience, perseverance and a jar of Vaseline and you can screw a Grizzly bear, if you really want to!
                      Good luck, and I hope another member can help you out. Even if I could help out it would be 10-14 days in the mail unless sent by UPS and to us Canadians that means You Pri*cks Suck as they rape us daily.
                      2-79 XS1100 SF
                        Rasputin, All I know is using the Suzuki part no. for the tiny washer/o-ring under the mixture screws is ONLY way of replacing them,OEM. N/A from MotherYammy for yrs. now. They ARE BS34 II's like the later 81/XJ carbs though, with enricher control like the XJ's.
                        • Jeffintampa
                          • Apr 2011
                          • 344
                          Please
                          Number 2 carb for a 1980 xs1100 SG
                          • Rasputin
                            • 3189
                            The Suzuki carbs are the same model Mikuni's that you are after. They were used in a different application but the actual bodies may be the same. I thought I would throw it out there in case someone knew for sure, as I could then send you a correct #2 body. I do not know for sure, but if someone does you get a carb body for shipping.... Not a bad deal.
                            2-79 XS1100 SF
                            • Jeffintampa
                              • Apr 2011
                              • 344
                              I think that would be easier than trying to fix the broken post
