looking for parts
  • tn-traveler
    • Aug 2014
    • 8
    • Lenoir City Tn
    looking for parts
    1980 sg studs and dowels good condition
    80 XS11 frame 3H5-002352 engine 3J6-010076
    • 9981
    Not sure what you mean.
      • 3969
      Like, from the jugs to the cylinder head?
      • tn-traveler
        • Aug 2014
        • 8
        • Lenoir City Tn
        yes from the crankcase through the cylinder head
          • 3969
          I do believe sir that the engines are the same upto the XJ's. I know for a fact a few here have an extra engine (or six) they could pull them from for yah.
            • 9981
            I've never been able to get them to bust loose. What's the trick?
              • 3969
              No tricks Greg, just luck.
              • tn-traveler
                • Aug 2014
                • 8
                • Lenoir City Tn
                mine were pretty bad, that's why I wanted to replace them
                  The only way to remove them really would be to heat up the block and use a pair of vice grips clamped to the shaft of the studs.. which is going to muff them up, defeating the purpose. Not much threads there to try to double nut them off. I'm going to assume this is purely for cosmetic purposes. Simple rust removal, primer and a good coat of high temp paint should fix you up.
                  Also, in this day and age, I'd be hesitant about posting your bike/engine's full VIN numbers online like in your signature. The first three digits is all that's needed for identification purposes.
                  • mxmikie
                    • Aug 2008
                    • 482
                    • Bouse az
                    http://www.ebay.com/itm/1-2-Drive-St..._Tools&vxp=mtr
                    careful what you wish for.........you might get it
