Fuel line T's
  • rappin
    • Jul 2006
    • 48
    • South Georgia
    Fuel line T's
    I'm looking for fuel line T's that I don't have to pay an arm and leg for?
    79 XS11
  • TomB
    • Aug 2006
    • 967
    • Cumbria, UK
    Mack did a cool repair and video'd it.
    Tom
      • 8064
      rappin,
      If you actually mean the tees in the lines, I got mine from my local Ace Hardware. They're made of brass and they were not expensive.
      If you mean the tees between carburetors, see the previous post.
      Here's another fix for the tee between carbs that I copied from another forum:
      The original "T" can be reclaimed and used again.
      1. Start by stripping the rubber coating off of it.
      2. Then, cut two sections of 1/4 Neoprene gas line and insert them into the cab inlets.
      3. Start to press the "T" into the Neoprene inserts in each carb
      4. Use a clamp to squeeze the carbs together.
      5. Check the length of the Neoprene sections to ensure they are not collapsing in the carb inlets.
        And if you end up with the arm and a leg payment option here ya go,
          • 8064
          Originally posted by natemoen
          I put those in mine. Very nice!
            Yeah, I will probably go with those if I ever need to replace mine.
            • rappin
              • Jul 2006
              • 48
              • South Georgia
              Thanks for the info. Nice video. Also the arm & leg $14.00 is alot better than $41.00 from ebay or $60.00 from Yamaha.
              I gues this is what I get for letting the bike set for 2 years. Shame on me.
              79 XS11
