Wanted front caliper retainer
  • 1234loft
    • Jul 2012
    • 77
    • Madison, Wisc.
    I am looking for a front brake caliper retainer.
    I believe it fits into the fork and the brake tabs fit into it.
    The retainer is most likely harder than the forks and that is why it is needed?
    Anyhow, I have a 1980 XS1100 Special.
    I am looking for the retainer for the right front fork. I do not know if they are the same for both sides. Looks like a stainless U shaped type part.
    I assume it is glued, or interference fit?
    Thanks, Jim
    http://www.nwvcp.com/pages/OemParts#...S1100SG_-_1980)
    Select bike, year, front caliper. Part number 10. Discontinued from Yammy....
    • mxmikie
      • Aug 2008
      • 482
      • Bouse az
      Thanks, Jim
      post a picture of what you need i might have it
      careful what you wish for.........you might get it
      • Rasputin
        • 3192
        • Lacombe, Alberta, Canada
        Somewhere on this forum is all the measurements you need to make your own as well. Memory escapes me right now but it was drawn out really well and all you would need to do is have it cut out and do some folds. If I find it when i am searching later I will post it. Mayhaps someone else remembers it too.
        2-79 XS1100 SF
        2-78 XS1100 E Best bike Ever
          There's a pic of the retainer here: http://www.xs11.com/forum/showthread...234#post378234
          If you want to make one, the original material is .030" thick.
          • Rasputin
            • 3192
            This is the only link I could find that has the info I wanted to say. It is not the original but it does have the drawing as well as ideas for further searching in order to find it.
            2-79 XS1100 SF
            • Lunatic
              • May 2006
              • 200
              • Watertown SD
              wow
              I have two of them in the bin of parts. I just figured that everyone had a pile of them on hand. If you still need one, email me at Bruns@wat.midco.net and I'll grab one from the garage for you.
