Need a front brake master cylinder and standard tank for 78
Also, I really need the reservoir. Previous owner stripped out a screw in the reservoir cap.
Any master cylinder of any of the years/models will work, except the lh and XJ. The special model has a bit of a slant to it because of the bars they had but still work just fine. BUT not all of the m/c are the same. they changed the way the reservoir mounted so you gotta watch if you try mix and matching. Do you need a working one or are you ok with rebuilding it?
You could also get a brand new one from WWW.mikesxs.com just make sure you get the one for dual front discs.
Same applies for the tank, any year/model will work. There are a few minor changes if you go with a special tank though.
1978 XS1100E K&N Filter
ATK Fork Brace LED Dash lights
Ammeter, Oil Pressure, Oil Temp, and Volt Meters Green Monster Coils SS Brake Lines
