Need a front brake master cylinder and standard tank for 78
  • GoRacers
    • Aug 2012
    • 81
    • Louisville, Ky.
    As the title states, I need a good front brake master cylinder and standard tank, both for a '78 standard.
    Can paypal immediately.
    Thanks
    Ryan
    78 E
  • GoRacers
    • Aug 2012
    • 81
    • Louisville, Ky.
    Also, I really need the reservoir. Previous owner stripped out a screw in the reservoir cap.
    78 E
      Any master cylinder of any of the years/models will work, except the lh and XJ. The special model has a bit of a slant to it because of the bars they had but still work just fine. BUT not all of the m/c are the same. they changed the way the reservoir mounted so you gotta watch if you try mix and matching. Do you need a working one or are you ok with rebuilding it?
      You could also get a brand new one from WWW.mikesxs.com just make sure you get the one for dual front discs.
      Same applies for the tank, any year/model will work. There are a few minor changes if you go with a special tank though.
      • GoRacers
        • Aug 2012
        • 81
        • Louisville, Ky.
        My current one works fine, but the lid on the reservoir doesn't seal because the previous owner ruined one of the bolts.
        I don't mind rebuilding the cylinder if the reservoir is in great shape.
        I'm trying to find one cheaper than new, right now.
        78 E
        • mxmikie
          • Aug 2008
          • 482
          • Bouse az
          i think i have a master for a 78
          • GoRacers
            • Aug 2012
            • 81
            • Louisville, Ky.
            You have PM.
            78 E
            • GoRacers
              • Aug 2012
              • 81
              • Louisville, Ky.
              replied to PMs. Didn't realize I was getting PMs, I hadn't turned notification emails on yet.
              78 E
              • GoRacers
                • Aug 2012
                • 81
                • Louisville, Ky.
                Still need a front master cylinder and reservoir...
                78 E
                • GoRacers
                  • Aug 2012
                  • 81
                  • Louisville, Ky.
                  found one on eBay.
                  78 E
