In need of a speedo cable for my standard. Tried that generic one cut to length and crimped etc... lasted a couple of days only.
Standard speedo cable
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top. -
If you can get that pin out, you could always try to turn the drive with a bit that fits inside and a slow drill speed setting. If it turns it should work fine. That might just break it lose if it is locked up. Or you could pop the wheel off and turn it from the inside. Either way if you are not confident in the drive mech, then I would try to manually turn it first rather than drive it and see if it breaks a cable or not. If it doesn't turn then I would look for a new one. If you do get it working a little cleaning and greasing might do wonders.1980 XS1100SG "Black Mamba" 28K
1979 XS1100F 33k (Current Project)
1981 XS1100H "Blue Balls" (Crashed and under repair
1978 XS1100E "Partsy"
Work Hard, Play Harder!Comment
