Hi everyone. I can't say I'm in desperate need of one but if somebody has an extra choke lever for an 81 Special... Mine is snapped off right where it meets the middle portion. My choke is still functional, just hard to get my fingers on it and would be nice to have a new one.
Carb Choke Lever
Those are pretty rare in unbroken condition... fairly easy fix is to fab a 'replacement' lever out of some 1/8" aluminum and attach it over what's left. If you shape to match, it will look OEM.
Another fix is to remove the choke lever assembly, then thread the end of the choke rod with a 8/32 die. You can then screw a small drawer pull on...Fast, Cheap, Reliable... Pick any two
Originally posted by crazy steve View Post
Another fix is to remove the choke lever assembly, then thread the end of the choke rod with a 8/32 die. You can then screw a small drawer pull on...Last edited by motoman; 04-05-2012, 10:48 AM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by crazy steve View PostThose are pretty rare in unbroken condition... fairly easy fix is to fab a 'replacement' lever out of some 1/8" aluminum and attach it over what's left. If you shape to match, it will look OEM.
Another fix is to remove the choke lever assembly, then thread the end of the choke rod with a 8/32 die. You can then screw a small drawer pull on...1981 XS1100 Special
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed." 2nd Amendment
Originally posted by JoshKeast View PostThe drawer pull isn't a bad idea though, I can get a heavy duty chrome one and use some loctite on it. Would you recommend removing the stock lever then, and leave just the rod sticking out?Fast, Cheap, Reliable... Pick any two
I'm afraid that would eventually strip and slip. I have access to metric and sae tap and die sets so it would only take me a few min to thread the rod. I am so glad I joined this forum. Lots of good ideas and advice from people that know so much more than me.1981 XS1100 Special
