79 Standard Parts
  • Lbrown311
    • May 2011
    • 311
    • Minneapolis, Minn.
    79 Standard Parts
    I just bought a new project and so far as I know, I need the following parts:
    Stock Seat pan and seat
    Side Covers
    Wire harness
    Rear plastic fender
    Rear rotor
    Rear brake line
    Handle bar controls and levers
    Front brake lines
    Mechanical advance and timing plate
    Ignition switch w/key (or a replacement that works)
    Rear Footpegs
    If anyone has a full set of bars with the controls and lines on them with or w/o the m/c on it I will take that to make it easier. Rather than piecing a front end together.
    Thats all for now. Thanks
    1980 XS1100SG "Black Mamba" 28K
    1979 XS1100F 33k (Current Project)
    1981 XS1100H "Blue Balls" (Crashed and under repair )
    1978 XS1100E "Partsy"
    Work Hard, Play Harder!
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    i can do ..... Rear brake line
    Front brake lines
    careful what you wish for.........you might get it
    • Lbrown311
      • May 2011
      • 311
      forgot. got any pics? you can email if it is easier. brown_basketball at hotmail.com
        I'll break this out a bit for more specifics...
        ...I need the following parts:
        Stock Seat pan and seat - Has to be '78-79 standard only.
        Side Covers - ditto
        Wire harness - ditto again; the harnesses are all more-or-less the same, but there's enough differences to make a swap complicated...
        Rear plastic fender - any will work
        Rear rotor - any will work, but the later ones are slotted. Any '78-79 will be exact replacement.
        Rear brake line - any will work (except for LH/XJ) Upper retaining bracket is standard only.
        Handle bar controls and levers - Any '78-79 for the switches, the rest any.
        Front brake lines - lowers, any except LH/XJ, upper standard only (assuming stock bars).
        Mechanical advance and timing plate - '78 or 79, but both parts MUST match to get correct timing.
        Ignition switch w/key (or a replacement that works) - any '78-79.
        Rear Footpegs - '78-79 if you want them to match the fronts, otherwise any.
        • Lbrown311
          • May 2011
          • 311
          New List
          I have some of the list taken care of so far. Here is what I still need. All for a 79F.
          Wire Harness
          Seat and pan
          Side Covers
          Rear rotor
          Rear Footpegs
          Thanks for the ALWAYS helpful info Steve. You finish that 80SG yet. I wanna see that puppy
          • Erik the Red
            • Oct 2005
            • 422
            • Northern MI
            I've got some of that stuff.
            I have the wiring harness, rear rotor, and rear foot pegs off of my parts '78 E I'd be willing to sell. If you still need them, PM me your email address, and I can send you pics if you want. Let me know.
            -Erik
            -Do what makes you happy.
            '79 Honda CB 750 K (2)
            '78 XS 11 E - "Rhona"
            ...and a 2nd E, for the goodies on it.
            • Lbrown311
              • May 2011
              • 311
              Oops
              So my update list wasn't as good as I knew it wouldn't be. Newest list.
              Wire Harness - pending
              Rear Rotor - pending
              Controls and Levers - pending
              Rear Footpegs - pending
              Front Brake Lines - pending
              Side Covers
              Ignition Coils w/wires, caps
              Stock Seat w/pan (I have the rear cowl in good shape)
              • Lbrown311
                • May 2011
                • 311
                bummers
                Just got the timing plate and advance today from ebay and the damn thing is from an 80...NOT a 79. So add that to the list again.
                • Lunatic
                  • May 2006
                  • 200
                  • Watertown SD
                  maybe you want to just come over here to Watertown SD with a truck and load up all of my XS11 and XJ11 stuff. It'd fill a full sized truck bed for sure. If you have the room to store all the parts, I'd rather sell the whole works than fuss with al the individual parts.
                  • Lbrown311
                    • May 2011
                    • 311
                    lol. you name a decent enough price and I'll think about it.
                    • Erik the Red
                      • Oct 2005
                      • 422
                      • Northern MI
                      I sent you a PM. I've got the coils and the timing plate and advance mechanism. Bike's a '78. PM me if you're interested in those too.
                      • Lunatic
                        • May 2006
                        • 200
                        • Watertown SD
                        500 for every engine, frame, wheel, fork, brake part, carb set, trigger set, brain box, gas tank, suspension, drive, electrical or any other XS11 or XJ11 part I have. I'd love to unload everything in one day. That would save me a LOT of hassle.
                        • Jfries
                          • Feb 2012
                          • 110
                          • South Bend , In.
                          how many do you got lol and any pics Lunatic?
                          1978 XS1100 Macho Maroon!
                          http://i1248.photobucket.com/albums/...s/DSC00361.jpg
                          • Lunatic
                            • May 2006
                            • 200
                            • Watertown SD
                            multiple brains of different models, at least three engines (only one is running though), calipers, wiring harnesses, 5 or so stator asemblies, starters, heads, cases, a truck load of stuff. I took a few photos tonight, but network54 won't let me link them anywere, so its not much help. Bottom line, is life is a risk. Bring a truck, come on over. Maybe its the deal of a lifetime, maybe its not. Who feels lucky? If I have to haul it all out to the driveway, take full inventory, photograph it all piece by piece, and list it all, then I might as well just list it all on ebay, piece by piece. If however, I can haul it all out ONCE, load it in someones truck and make it all go away so I can get on with other projects, then its worth selling it all as one big lot. Yep, I'm puting it up there as a gamble for someone. Who's willing to roll the dice and come over?
