Rear brake shim for '80 xs11 mns
  • bikemight
    • Sep 2011
    • 7
    • seattle, wa
    I'm looking for a rear brake shim for a 1980 xs1100 midnight special. I am rebuilding my rear brake and as I got the pads out realized there is no brake shim. If anyone happens to have one I'm very interested. Thanks.
    -robin
    1980 xs1100mns
    Ss lines
    Mikes xs 16 mm bore master
    Superbike bars
  • petejw
    • 2269
    • sydney australia
    hi robin,
    if u cant get hold of one, u can make urself
    one by cutting a soda can up, its only there
    to help stop the brakes from squealing.
    heres a pic that might help u out.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • SFerinTEXAS
      • Jun 2006
      • 877
      Shim
      That shim IMO is completely unnecessary on the rear brake as is the small screw that goes thru the back of the caliper . Been running w/o both for 6 yrs with no ill effects. I will note this applies to the 80mns, not the 81. Completely different designs.
      Those items may be of use on the front std model brakes which is the same design but the horizontal placement on the rear makes them unnecessary. Eliminating the small screw also makes pad replacement a 1 minute operation. Again REAR only.
      79SF
      XJ11
      78E
      • bikemight
        • Sep 2011
        • 7
        • seattle, wa
        That's some good info. Thanks guys.
        -robin
        1980 xs1100mns
        Ss lines
        Superbike bars
