1980 XS1100G rubber boot for rear master cylinder needed
  • pvsa
    • Jun 2010
    • 12
    • Richmond, VA
    The rubber boot connecting the rear brake lever to the rear master cylinder is cracked and leaks brake fluid. Can't find one anywhere so far. Any assistance would be phenomenal. Thanks
  • CatatonicBug
    • 6117
    • Clinton, UT
    That rubber boot is only a dust cover. If it's leaking, the whole master cylinder kit needs to be replaced (or at least cleaned and re-seated).
      Cbug is correct. If your leaking fluid then you need to totally disassemble the master cylinder and go through that.
      • pvsa
        • Jun 2010
        • 12
        • Richmond, VA
        Thanks guys. First rebuild (obviously). I will go back through and check it out. Unfortunately the Clymer manual doesn't help too much with the brakes. I need some good instructional pics.
          pvsa, take a look at the Yamaha Online Parts Catalog and select: motorcycle, 1980, XS1100G.
          Zoom in on the illustration in the "Brake" category and you can see how it all fits together, including the internal parts for the master cylinder.
          • pvsa
            • Jun 2010
            • 12
            • Richmond, VA
            Always comin' through in the clutch Scott! You've saved me more than once, for sure
              Oi! Is that you, Paul?! You're welcome!
              • pvsa
                • Jun 2010
                • 12
                • Richmond, VA
                I'm just not sure of the order in which everything goes back in. I see the brake repairs thing in the tech tips section but there's nothing on the rear master cylinder, just the front...
                  Well, the rear brake is almost exactly like the front brake except, erm, well, it's at the rear!
                  Paul, the brakes are just as important as all the go-fast stuff. If you are still even a little bit uncertain about how to repair brakes please find someone with experience to do the work or at least watch carefully and advise while you do the work.
                  • pvsa
                    • Jun 2010
                    • 12
                    • Richmond, VA
                    I got it going. Once I finish all that I can on it, I'm going to get a guy back home to check it all out, make sure all is well.
