Carbs
  • arden666
    • 5
    • Reno, Nv.
    Carbs
    Looking for a carbuerator setup off a 1980 xs 1100, and or advise....... i have 2 cylinders not firing. the bike is a 1980 but has 79 carberators 1 and 4 fire 2 and 3 do not.
  • Yahman
    • Mar 2008
    • 779
    • Salem, OR
    Have you checked the coils? 2 & 3 use the same coil.
    Larry
    82 XJ1100
    80 XS1100G (Project bike)
    64 Yamaha YA-6
    77 Suzuki TS-185
      Yep, 2 and 3 are typically an electrical issue. Start at the pickup coil(s) looking for a broken wire. Look in the tech tips. This usually shows up as an intermittent problem, but could go this far if not fixed I would think. Then as indicated, check the coils. Also, check your wiring to the coils, check all connections and clean them good.
      • dragxs11
        • Jun 2003
        • 519
        • Reno, NV
        I've been working with arden.. on this. We fixed the pickup coil wires. Removed the carbs again and I found a few probs. Fuel lines clogged, and most notably, 2 & 3 pilot air screws busted and jammed in the ports. Diaphrams turned around wrong as well. We're gonna need a couple rebuild kits for parts and a few things that the kits don't provide.
        What I'd really like to know is what the t's and hoses on at the top of the bowls are for. 80's+ don't have those, wonder why?(not the fuel feed... above at the diaphram level, but at the top of the bowl chamber)
        1980sg-Stocker-- Sold
        1980sg- Cruise Missile- Sold to RODS454
        1990 ATK 604- Ditch Digger
        2005 BMW K1200S- Killer Bee
        2005 Suzuki GSX-R 1000- trackbike
        • xs11bobber
          • Jun 2009
          • 229
          • Cromwell, Indiana
          They are for air. Originally plug into the stock airbox just like the oil breather hose. There are "2 types of BS34" carbs. Old/new. There's a few differences. You can search them here.
          Josh Yoquelet -- I'm having dreams of my XS
          '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
          '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
          '81 Air forks w/23,000 miles
          New steering head races and bearings
          '78/'79 standard wire harness
          Drag bars, w/Mikes controls
          T.C.'s fuse block
          PNM Coils
          7mm Dyna Wires
          NGK Resistor Caps
          Custom 1" clutch and 9/16" MC
          http://xs11bobber.tripod.com
          • GARTHXS
            • Nov 2007
            • 1631
            • Seattle
            plugged pilots
            I just went thru this on mine and it is a pita but I tried that new tip and tossed the whole rack in the freezer for like 5 hours and used a 90 degree pick and the box end of a 17mm aplied a little pressure and it popped super easy I couldn't believe how well it worked thanks (tdodge7)
            91 kwaka kz1000p
            Stock
            ( Insert clever quote here )
