Protecting Gaskets - Use Pam Spray
  • xs11
    • 130
    Protecting Gaskets
    Use Pam Spray
    If you frequently disassemble parts while working on your engine, such as removing the cam cover for adjusting valve spacers or removing a carb float bowl, spraying PAM non-stick spray on the gaskets prevents them from sticking to metal surfaces. The gaskets won't tear during disassembly - allowing their re-use.
