El cheapo Pod Filter mod (my version)
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    I got my hands on a set of the K&N knock off filters. I have seen posts about the rubber insert closing off the jet ports, so this tip will correct that issue. I also found the filters fell off the rubber piece too easily when installed.
    Here is what I came up with. Took a spare airbox and removed the tubes:
    I cut the tubes just aft of the retaining groove:
    Removed the rubber insert from the pod filters:
    Crammed the tube into the pod filter. It is a chore, but it will go. Much more snug than the rubber insert included with the filter.
    Noticeable difference in power. Nothing earth shattering, but there is a boost. This will likely lean out the mixture, so a rejet with bigger jets will probably be needed. I also found a breather filter that looks similar to these at Oreilley's, for about $10. Not bad for less than $50
    Ich habe dich nicht gefragt.
