Brighter tail/brake lights
  • xs11
    • 130
    by BMWDUCMAN@aol.com
    Date: Sat, 27 Jan 1996
    On bikes that use a 1157 tail/brake combination bulb, a simple and inexpensive upgrade in the brake light illumination is readily available.
    A 2357 tail/brake combination bulb, available at any auto parts store, will produce the same brightness for the tail light (3 lumens), but will produce 25% greater brightness for the brake light (40 lumens vs. 32 lumens).
    The volts required to power the 2357 bulb are the same as the 1157, but there is a slight increase in the amps required (2.1 for the 1157, 2.2 for the 2357). The resulting increase in watts used is only 1.28 watts, or a 4.76% increase over the standard 1157 bulb.
    The only draw back to using the 2357 bulb is the rated hours of service for the brake light element is much less (400 hours for the 2357 brake light element vs. 1,200 hours for the 1157 brake light element). The tail light element in both the 1157 and the 2357 are rated at 5,000 hours. Assuming one rides 4 hours per day, 365 days per year and uses his/her brake 25% of the time, if the brighter 2357 bulb is replaced annually, there should be little chance of in-service failure.
    Cost for a 2357 bulb is about 97 cents.
    In an effort to provide too much info on brighter tail/brake lights, the 1157 (standard), the H1157 (halogen) and the 2357(newer version of standard), I have the following info:
    Tail/brake lights: A comparison
    Specification1157H11572357
    Volts(high)
    " (low)
    Watts(high)
    " (low)
    Amps (high)
    " (low)
    Base
    Candlepower(high)
    " (low)
    Lumens(high)
    " (low)
    Average life(high)
    " (low)
    12.8
    14.0
    26.8
    14.0
    2.1
    1.0
    S8
    32
    3
    402
    38
    1,200
    5,000
    12.8
    14.0
    49.9
    unknown
    3.9
    unknown
    S8
    107
    25
    1,350
    38
    400
    400
    12.8
    14.0
    28.1
    14.0
    2.2
    1.0
    S8
    40
    3
    unknown
    320
    400
    5,000
    The H1157 (halogen) is manufactured by Candlepower, Rockville, Maryland (301) 340-0224.
    You can order the H1157 for $10.95 from Nichols Distributing, (800) 323-4488.
    The biggest concern is the increase in amps and watts (heat) when switching to a halogen bulb. The H1157 brake light element produces 86% greater watts (heat) than the standard 1157 brake light element, the 2357 brake light element only produces 4.8% more watts (heat). [What this means is that if you're not careful, you could easily melt your taillight by using the halogen bulb.]
    Note: "Heat" is measured in "watts", hence, they are the same.
    The other concern with using the H1157 or the 2357 is the shorter service life. The H1157 is rated to last only 400 hours on low (tail) and high (brake) elements. This is drastically down from the standard 1157 and less than the 2357 low (tail) element. Depending on your riding, this problem can be avoided by scheduled replacement.
    Hope this info helps for safer riding.
