Spark plug cap resistor removal
    • 8932
    Okay, we're gonna remove the resistor from the short NGK5Ω caps used on cyl 1+4.
    Get some 5/16 oak dowel rod and drill a small hole in the end.
    Thread it on the screw where the wire attaches.
    Put the dowel in a vice leaving a small gap so a screwdriver can be used to pry.
    The piece you are removing is held in there with 2 star washers, making it appear to be non-removable.
    Now, find a piece of metal the appropriate length and put it in place of the resistor.
    Reassemble the spring and metal bolt and with the screw and star washer attached to the wooden dowel, tap it back into the housing.
    See post #5 for the final assembly photo.
    • 2160
    Thank you.
    I just bought one of the last sets of non-resistor plugs I could find.
    Same thing on my 750.
    I assume XS11 cylinders 2&3 also have resistors?
      • 8932
      Yes, the longer caps for cylinders 2+3 have resistors which can be removed rather easily. Use a flat head screwdriver to unscrew the piece at the spark plug end of the cap.
        • 2007
        The piece you are removing is held in there with a star washer, making it appear to be non-removable.
        Nice description. Any chance of pictures at this point?
          • 8932
          Tighten screw with star washers flush with dowel before pushing back into the cap.
