Home Made Vacuum Gauge Carb Synchronizer
  • nashville_bill
    • 605
    • Nashville, TN
    Home Made Vacuum Gauge Synchronizer
    by Bill Murrin
    I have made a cheap carb synchronizer out of a vacuum gauge, 3/16ths" tubing, four screw aquarium valve and a home made plenum. The gauge($8) is from Harbor Freight and the aquarium valve($4) is from my local fish store. The plenum tank is just PVC pipe with a couple of brass taps screwed into it($3). The plenum was used to
    dampen the fluctuation of the needle on the vacuum gauge.
    Click image for larger version  Name:	20020830-mysyncrotool.jpg Views:	0 Size:	83.1 KB ID:	860322
    Here is one of the brass plenum fittings:
    Click image for larger version  Name:	20020830-brassplenum.jpg Views:	0 Size:	31.9 KB ID:	860323
    Closer shots of the gauge and valve:
    Click image for larger version  Name:	20020827-synchrovalve.jpg Views:	0 Size:	81.6 KB ID:	860324
    Click image for larger version  Name:	20020830-gaugeinuse.jpg Views:	0 Size:	100.4 KB ID:	860325
    Operation: Adjust each carb by turning on the valve that is connected to it's manifold while the other three are closed. This takes a little longer than the mercury sync but it is cheap and you can open the throttle as much as you like without worry of ingesting mercury.
    If I had it to do over again I would make the plenum out of larger diameter PVC and have a threaded cap on one end so all the parts would fit inside.
    Bill Murrin
    Nashville, TN
    1981 XS1100SH "Kick in the Ass"
    1981 XS650SH "Numb in the Ass"
    2005 DL1000 V-Strom "WOW"
    2005 FJR1300 Newest ride
    1993 ST1100 "For Sale $2,700" (Sold)
    2005 Ninja 250 For Sale $2,000 1100 miles
