Gear Oil Dipstick
  • xs11
    • 130
    Gear Oil Dipstick
    Gear Oil Dipstick
    by Doug Heinen
    The Official Yamaha (TM) stick is put together as follows. The short end is for measuring REAR drive, and the long end is for measuring the MIDDLE drive. The two horizontal lines at each end indicate the low and and high range for oil.
    Click image for larger version  Name:	dipstick.png Views:	0 Size:	865 Bytes ID:	861036
    Width across each end is 1/4" or 6mm
    Hope this helps, best I could do with ASCII Draw.
    Note added 7/30/02
    by sixtysix
    The original dipstick is still available and less than $5.00 at your local Yamaha dealer.....Part number for the gage is:
    2H7-2815A-00-00 (Gauge, oil level)
    photo added 8/12/02 by Mike Hart
    Click image for larger version  Name:	20020902-dipstick.jpg Views:	10 Size:	85.9 KB ID:	860319
    Here is a photo of a dipstick available from Mike Farnworth's site under 'Goodies':
    Also reference member CatatonicBug website for 10 printable, disposable dipsticks
