Oil Filter Reassembly
  • xs11
    • 130
    by Sid Hansen
    When changing the oil filter does the spring go on under the filter in the "bowl" or on top of the filter against the engine???
    From bottom to top: case, spring, washer, rubber insert, filter, rubber insert.
