Clutch Cleaning and Refurb
  • xs11
    • 130
    by Ralf Koehler
    6/19/00
    A couple of weeks ago I was complaining about my dreadful clutch, hardly disengaging at all, grinding 1st and 2nd gear teeth... I found out that it was plain adhesion causing the stickyness!
    I took it all apart and performed the following work:
    • Meticulous filing of all edges on friction plates, steel plates, hub & clutch basket
    • Light sanding of old friction plates (thickness after 60k = new value) with automotive 120 grit paper to get rid of the glaze
    • Medium sanding of steel plates with 80 grit; cleaned everything with turpentine
    • Mounted steel plates 180 degrees turned, so that rounded edges now face the crankcase
    • Added 0.070" shims to springs (yes, I've got strong hands)
    • Treated new gasket with PAM Spray (both sides)
    The result is amazing; the clutch works almost like new. Works out my left hand too. Total investment was several hours of labour plus one cover gasket. Actually, I had to use hammer & chisel to knock loose the 27 mm nut.
    One more tip: once you have that side cover off, don't miss the opportunity to clean the inside of the metal piece behind the oil level window!
