Out of Sync?
  • DRyder3178
    • 4
    Out of Sync?
    I've heard a lot about syncing your carbs to get optimum performance. Can anyone tell me some of the symptoms of a carb set being out of sync? BTW I have a 1980 XS1100 Special. Any help will be appreciated.
  • randy
    • Dec 2003
    • 4521
    Symptoms of out - of - sync carbs:
    Rough idling.
    'hunting idle' - won't hold a steady rpm.
    hesitation
    bogging
    one or more exhaust pipes off color.
    backfiring through carbs.
    popping on decelleration.
    plugs color differs widely.
    yadda, yadda
      • 5061
      Yadda, yadda? Does that leave the door open for other possibilities? Is that for providing a sufficient amount of wishy-washyness? I am kidding of course.
      yadda, yadda
        Basically, if you do not know the last time it was sync'd, it most likely needs to be done. This is a fairly simple procedure that you can do yourself. The tool you need should cost less than the hour of shop time you would be charged if you took it to a dealer.
        • mro
          • 4276
          • Hayward, California
          Before finding this site, went to local yam dealer for a manual. Wanted $65.00 , so just ordered a carb part I new that I needed. Got my 80G running, but w/issues.
          Found this site, read the tech tips and one had mentioned using a vacuum gauge to sync carbs. By this time I had the 80G running pretty good. Made the gauge sync tool outa stuff found in my shop and tried it out.
          Surprised how much better she runs, especially noticeable better throttle response.
          mro
          • randy
            • Dec 2003
            • 4521
            Skids,
            Where carbs are concerned, the door is always open to other possibilities!
            Oh, yeah, forgot another: YMMV
