Is there another valve shim tool available on the market? Or some other way to get the valve shims out?
I, like many of you, am getting very frustrated with this motion pro piece of garbage. It doesn't even touch the top of the valve when the valve is all the way up. My clearances are way under the minimum on some valves. So I don't want to run the engine without getting them adjusted. I emailed motion pro about the problem last night. We will see what they come back with.
Glenn
Glenn
.....Ummm...please?
