Tire change cable
  • COOL TOM
    • Jul 2005
    • 288
    • CANTON, IL
    Tire change cable
    Could someone measure the cable that holds the swingarm up when changing tire. Measure from end of loop to end of loop inside. If someone has one for sale i would like to have one, if not then i will make my own.
    Thanks Tom
    82 XJ1100 DAILY RIDE
    78 XS1100E FIXING UP
    79 XS1100F PARTS BIKE
    Thanks Tom
    82 XJ DAILY RIDE
    79 XS1100SF NAKED BIKE
    80 XS1100SG FULL DRESS BIKE
    82 XJ IN THE ROUGH
  • stevo
    • 64
    • buford georgia
    i just went and looked ..i've got that cable ..came with 79 f..has all kind of loops and hooks and crap on it ..looks in good shape .you can have it if you pm your address...i've got four into one with removable muffler so i don't need it stevo
    • mro
      • 4276
      • Hayward, California
      crap on it
      Just changed both tires few days ago.
      Was I supposed to have a cable thingy???
      mro
        • 5069
        Re: crap on it
        You can probably unbolt the shocks to make the axle clear the muffler... Is that what you did?
        mro
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          even when i used the cable i manage to ding the right muff and getting the cotter pin in the castle axle nut scratches the left muff, just tight all over
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • mro
            • 4276
            "You can probably unbolt the shocks to make the axle clear the muffler... Is that what you did?"
            nope,
            removed two bolts right rear muf mount. Insert heavy pry bar w/rag between muf and frame which held muf down just barely enough. Used crescent wrench to remove nut on axel and taped it out w/drift pin.
            Went to put cotter pin in when done. No way w/muf there, so put a clevis pin in it for now.
            Was expecting to see "more beefer?" gears in hub/final drive tho.
            mro
            btw
            it's an 80G w/stock muf's
