Just bought an 81 Midnight special (xs 1100). It seems to be running a little rough. Carbs backfiring.
The intake assy has been removed and replaced with 4 individual air filters. The fuel lines from the petcocks have been modified. The two front nipples on the petcocks are connected. The two rear nipples go to the carbs (left petcock to the two left carbs, right petcock to the right carbs). I can get it started and seems ok at idle. But when I go to rev it up, I get some backfire out of maybe two of the carbs. Not sure what the problem is. From previous forum discussions, I see that there could have been an "octopus or spider" diaphram. I don't see any sign of that. So that is why I am guessing why the two front nipples of the petcocks are tied to each other. The other two lines did have filters on them, but I removed because I thought they might be restricting some fuel. So now I have a direct line from the petcock to the carb nipple. When I did this and turned on the petcocks, I had fuel running out of the carbs. I ended up turning off the petcocks and starting it up and letting run briefly, then turn on the petcocks. It seemed to be ok after that.
Anyway, the way it stands is that I continue to get this backfire when I am just running at lower rpm or idle. I have run it up the road a bit and it seems ok when it is wide open....But I am not satisfied with that. Any suggestions?
thanks
bk
thanks
bk
