Changed the speedo on my XJ. Pulled the needle to remove faceplate from old unit to put on replacement, old faceplate was in beter shape. Think the speedo is reading to fast, parhaps I got the needle in the wrong place on its shaft. Anyway, it indicates 55 MPH at 3,500 RPM in 5th gear...been so long since I had a speedomoter I can't remember if this is accurate. 65 MPH is indicated at 3,900 - 4,000 RPM. Can someone tell me if these RPM - MPH numbers are pretty close?
If anyone is going to try swapping speedos on the XJ, get one of those ratcheting, 90 degree Phillips screwdrivers. Will save a lot of frustration and time!
