Got some new carbs today, and my question is...
My old set up was with the Octuipuss, two petcocks, and my carbs only had two fuel connections...The new carbs I got today have four connections. between 1&2 there is one going to the floats...and there is another one about that. And then between 3&4 there is the same set up, with two connections. I went searching in the manual, and all the pictures they have in there, are of this four connection carb, but the diagram in there is of my older carbs, with only the two connections. So I am wondering...can I make this work guys?
Thanks...Artic_rider
Yes, they will work just fine. The lower "T" fittings are for the fuel lines from your petcocks. The Upper "T's" are the float bowl VENTS, just "T" them together, and then stick a filter on the end of the lines to allow them to breath!!! DON'T CAP THEM OFF!!!!
