having just completed my 3000 mile tour of mexico, and quickly coming up on 80k for the old girl, i decided to do a compression check and see what the future looks like for our relationship. tried it once yesterday. apparently i was doing it wrong. bike was warm, but i wasn't holding the throttle open. i also suspect the battery was weak, as it had sat for almost 2 weeks and was not cranking all that hard. yesterday, all cylinders read EXACTLY 100 psi. i was bummed, but puzzled, since it ran so well. so i added seafoam to the crankcase, changed the oil and went for a nice long ride today(ran like a champ!). came back, read up on the proper procedure, and tried it again(throttle wide open, battery was cranking harder). now for the amazing news-the readings varied, but were all between 152 and 160 psi. now i'm cautiously optimistic. my question is, can this be possible? it seems a bit high, even for a new bike, let alone one with 80k on her! i'm stoked, because it seems we shall continue our relationship, but i wanted to ask the experts. your thoughts are always appreciated. mark...... ps-my mechanic buddy and i did a comp check when i first bought the bike, way back at 28k, and 3 cylinders read above 150, with one a bit low(120ish), that he said was probably a stuck ring due to sitting for too long, and that a good long ride would probably unstick it. so i rode it from tx to az and back. it appears to have unstuck...heehee
Could This Be???
You might run some carbon cleaner or some Marvel Mystery Oil in the gas for a few tanks. Carbon buildup can make your compression go up also... taking up room in the cylinder. I don't know if the seafoam cleans that... if so.. sorry.
Or Techron in the gas. My local auto mechanic is big on Techron for cleaning injectors and decoking engines. He likes MMO for freeing stuck lifters, worked for me.Shiny side up,
650 Mike
XS1100SF "Rusty", runs great, 96k miles
XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]Comment
i've used the seafoam in a few tanks of gas(and the crankcase, once) and gas additive frequently. don't misunderstand-i'm quite pleased with the compression readings, i was just shocked to find them so high.79 xs1100F
75K and counting...
76k...
79k...
80k...
86k...Comment
RUSH-your humor is my cup of tea. ps, here's a link to the mexico journal. http://www.xs11.com/forum/showthread...5&pagenumber=179 xs1100F
75K and counting...
76k...
79k...
80k...
86k...Comment
I have an oldish motor (125k) that measure 120 - 125 psi. I found I can get these number to be higher or lower, depending on the process. I am more concerned about consistency across the 4 cylinders. My "F" does not have the snap it once had or that of my "SF" with 20K on it. But, it is smooth and quiet. I have never tested my "SF".DZ
Vyger, 'F'
"The Special", 'SF'
'08 FJR1300Comment
Can't complain about those #s, darned good for an old bike. I haven't tested my SF but my XS650H was 143 & 147 right after I got the motor unfrozen. I should test it again now that it's been ridden a bit. Probably better, the motor seems strong.Shiny side up,
650 Mike
