Originally posted by Dennyz
Did you remove the cable house braket that bolts to the top of the carbs (like to remove the slides)? If so, make sure it is on right. It might possible need to be bent down a bit.
If your cable has a brass button on the carb end, that allows the cable to slide through, make sure the cable end is seated in the brass button.
... of course there are those pesky PM things that I haven't read yet..... from some guy name moderator ....
