Hello, I'm new to this forum. My first question is this: What is the max tire size and brand that will fit on an XS11 without rubbing on the drive shaft? If this has been answered before, please direct me to the thread. Thanks.
Tdog
Tire profiles vary somewhat from brand to brand within the same nominal size. Many on this forum have mentioned running 140 section Dunlop Elite IIs and I am running a 140 section Avon Venom X on my Special, it barely clears. So with those particular tires at least you'd be OK with a 140. Is your bike a standard or a Special?
Shiny side up,
650 Mike
XS1100SF "Rusty", runs great, 96k miles
XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
Thanks for the tire info 650Mike. The XS11 in question and I have been separated for many years and I can't remember if it is a Standard or a Special. After our reunion (next month I hope) I will know more.
T
The 140 profile will just barely fit. Best to use the Black Wall style. My raised white letters rub! Also, IF you are planning on doing much 2 up riding, then you might want to stay with stock 130, the tall sidewall does flex a bit under the stress of the weight of 2 up, and I got considerable more rubbing during the time I was running 2 up!
79SF "The Teacher" . . .basket case! History shows again and again,
2 reason why those Kawis run the rubber they do. (1) The Kawasaki Police 1000 is an older design (like our bikes). (2) Skinnier tires just handle better. Yeah I know race bikes use fatter rubber these days but it's radial and they need the traction more than the handling. We're not racers. Our bikes touch hard parts to the pavement before the tire lets go in most cases (unless you feed it too much gas in the corner). Worst possible combination is what those Harley clone customs run, a little skinny front and a great big rear. This makes the bike stand up under power in turns causing the bike to want to run wide. The best handling bike I've ever owned was my G12 Matchless bobber. I ran 3.25x19" tires on both ends. Steering was perfectly neutral at all lean angles, braking or under power. Cornered as if on rails. Easy to be fast on a bike like that.
Interesting aside about Kawi Police bikes. I was talking to a CHP officer many years ago (he stopped me for speeding) and he told me that the bikes are very sensitive to weight distribution and that the CHP had trouble with instability in high speed chases until they moved the radio a few inches forward. He said he loved his Kawi and never wanted to go back to a Harley again. Let me go with no ticket. CHP now rides BMWs.
Shiny side up,
650 Mike
they now how to move on those machines, i guess their training is harder than navy seal training, so why would i ever need to go over the rims size limitations, i want handling, skinny rules!
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400
