Whoops - broke carb float pin post...
  • Shuriken
    • 1093
    • Southwest USA
    Can it be repaired or should I just use a spare carb from a spare rack?
    I was pondering on getting a set of 80 carbs for my 79sf because of better diaphragm availability... ??
    I have a spare set of 78e carbs I think, wonder if I can use one of them...
    Ben
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
    • 5062
    Ben, my best-runnin' bike has a broken goal post. No biggie if the pin is held tight by one end.
    • Shuriken
      • 1093
      • Southwest USA
      Did you leave in the broken fragment or just let the float pin rest through the one side?
      Ben
      Formerly:
      1982 XS650
      1980 XS1100g
      1979 XS1100sf
      1978 XS1100e donor
        Whatever floats your post!?
        Hey Ben,
        I had a broken post on my #2 carb, fixed it with Magna-Steel type stuff from auto store, held just fine, but I got the post and pin at a slight angle and it caused intermittent sticking and flooding. I finally pulled it apart, cleaned it up and fixed it LEVEL with J-B Weld. It's held for 2 years now, and no more flooding!
        You can build up around the broken area of the post, and then file/grind it down once it cures to allow for the float bowl to fit, it's a snug area there!
        • Shuriken
          • 1093
          • Southwest USA
          Wondered about that but wasn't sure if it would hold while constantly submerged in gas. I will try that and use a new pin, since the current one is bent.
          Ben
          Formerly:
          1982 XS650
          1980 XS1100g
          1979 XS1100sf
          1978 XS1100e donor
          • GNEPIG
            • Apr 2005
            • 1657
            • fl
            .. ever since I received my KT pin press from Ken Talbot I have not had any problems removing my stuck float pins.. it was so much fun to use, now i have 10 racks of carbs laying around in piles all over the place.. now if he could come up with a tool that would get me to actualy finish a project (like a boot in the @ss), i would buy one of those too.
            • Wet Rock
              • Dec 2005
              • 51
              Glad to hear a report about the Pin Press. Prometheus was the only other that gave info in org. thread.
              • GNEPIG
                • Apr 2005
                • 1657
                • fl
                .. i think $10 bucks is a cracker jack price also. but only us really cool guy's have one, so if you are not cool then dont bother getting one
                  • 5062
                  Oh boy... you have to make a plan!
                  • prometheus578
                    XS-XJ Super Guru (RESIGNED)
                    • Aug 2004
                    • 4012
                    • Olympia , Wa.
                    "Carb Boot?"
                    No need to buy one of those, GNEPIG, I'll boot you in the a$$ fer free!
                    • Shuriken
                      • 1093
                      • Southwest USA
                      I never heard anything about a pin press...
                      Formerly:
                      1982 XS650
                      1980 XS1100g
                      1979 XS1100sf
                      1978 XS1100e donor
                        • 5062
                        To answer this from some time ago (oops), Yes, I just left it pinned from one side. It is rigid enough.
                        Ben
                          AE7F - have a look at the stuck float pin thread.....
                          • mro
                            • 4276
                            • Hayward, California
                            Hi Ken
                            If you need to make any more of the pointy parts for your press found you can make them in seconds using a die grinder w/cut off wheel instead of a file.
                            mro
                              Good idea there, MRO. I did find that running the drill press at its highest speed while applying the file also made that phase much quicker.
