New Clutch Rebuild Tech Tip!
    Hey there folks,
    Just wanted to pass on this info, after recently needing to rebuild my clutches, putting in new plates, springs, and adding an extra steel plate, I took a bunch of photos, and made a little Visual Walkthru Tech Tip about this process, it's in the repairs section, just follow this link if you want to see it!
    Clutch Plate and Extra Steel replacement Tech Tip
    Okay Tod/Trbig, this should get you thru it in the FALL!!
  • gerkenbruce
    • 392
    • Upstate NY
    Nice job TC
    XSively
    Bruce
    Bruce Gerken
    '79 XS1100SF
    "The Black"
    '2009 BMW k1300GT'
    The Red Sled.
    St.Augustine (354-430 AD) wrote,"The world is a book and those who do not travel read only a page . Well motorcycles turn the book of the world into a page turner. That is often impossible to put down.
    • bandet01
      • 698
      • connersville indiana
      nice i needed that i am getting ready to change mine and add a steel to mine
      79 yamaha xs1100f standard
      best 1/4 mile 13.282@99.40
      • mro
        • 4276
        • Hayward, California
        Thanks TC
        been wondering where you guys have been putting the extra plate.
        mro
        • remccool
          • Dec 2005
          • 129
          • San Antonio, TX
          Perfect timing!
          I will be changing my clutch plates out soon (getting them from Andreas).
          It is adjusted now so that I don't get the slipping when I accelerate, but now the gears grind and clunk when I shift. I was looking at the Clymers and wondering how much it would cost for a shop to it! Thanks, the step by step instructions you have provided should make it easy enough for even me to do!
          Thanks!
          "DuctTape"
          - XS1100E (Project: Has a long way to go)
          - 2008 Honda Goldwing GL1800P
          Two Lane Road Riders Association
          Southern Cruisers
          TMRA, TxCOC, etc....
          • GNEPIG
            • Apr 2005
            • 1647
            • fl
            sandwich?
            Here's the clutch pack with all of the plates back in it starting with a friction plate on the bottom, and then alternating steel and friction, but when you get to the 4th steel, then stack the EXTRA STEEL plate next to it, then continue the friction/steel sandwich!
            .. it must have been about lunch time when he got to this part.
            good job Curtis
            • remccool
              • Dec 2005
              • 129
              • San Antonio, TX
              What is the advantage of the "extra" steel plate? Is it for making up for springs that are too short.... or worn plates..... or.....?
              "DuctTape"
              Southern Cruisers
              • GNEPIG
                • Apr 2005
                • 1647
                • fl
                .. after so many miles and so much abuse(because these bikes are so fast, they are fun to abuse), the clutch basket gets worn also. the extra steel helps the springs, the worn friction plates and the clutch basket ,to a point.. also a motor oil that works WITH your friction plates is a plus
                • pathfinder
                  XStremely XSive(Deceased)
                  • Apr 2004
                  • 483
                  • Houston, TX
                  Great tech tip
                  Another perfect timing, got my new clutch pack and springs in today. Broke it all down tonight in about an hour, and hopefully back in tomorrow night after the only Saturday of the year I have to work doing inventory.
                  The only catch I had was actually removing the cover. I beat on it with a rawhide mallet to get it started but no joy in getting it off. Took the two screws from the round cover and threaded in about halfway and with a little gental pulling with a claw hammer (don't laugh) it came right off.
                  78XS11E
                  • scalded dog
                    • 458
                    WOW! that is cool, thanks T.C. Later 'Dog
                    • pathfinder
                      • Apr 2004
                      • 483
                      • Houston, TX
                      Wow again
                      I forgot to post all back together in 3 hours & working perfect. So about 5 hours end to end with dinner included in the time. I was going slow and methodical, meaning once is enough for anybody.
                      78XS11E
                      • mro
                        • 4276
                        Tanks TC
                        Added steel to clutch today. Major improvement. All friction's were just w/in spec but had slip when hard in third. Went out to night and was a menace
                        mro
                        less than 2 hours, remove clutch from LG, "steel" a plate and install in 80G. Do wheeley in parking lot to test
                        mro
