Well Sid, and all that have been helping me through the mongrel/Rusty swap and mix..
I went on a ride yesterday (first since Deuce)... the rear tire leaks a little, but i'm riding like a granny anyway....
well about 65 miles and a ferry trip later.. the same problem came up that i had at Deuce... figuring it was carb again like i thought .. (and sid helped)...
losing one cyl... then gaining it back if i let it drop to about 1500 rpm.. well by the time i stopped fof dinner.. i was only about 65 miles from the ferry back home. and another 15 miles after that..
wel then i started backfireing, popping, and even at times dying totally.... figuring im not gettting stuck on HWY 101 in the dark, i figured it was the wires in the pickups... (32K on the motor.. never before addressed by my uncle.)... i limped home.. missing 3 ferrys and making the midnight one...
rolled in the driveway after a lot of nausiating 20-30 mile per hr travel..
and today pulled the cover.. after reading the info about the "hourglassing effect" of the broken wire..
one was sooo bad it almost hourglassed just by looking at it.. it was that apparent... .
the other one looks like it was pinched between the mount and the coil.. (mmm looks like someone broke it up on this side.. then fixed it up..)... also that seal is leakin...
so atleast i know another thing i can soon check off the list.. as i try to get this thing done..
