Hi,
I've decided to start drag racing my XJ1100 and need some tips. I've been bracket racing cars for over 10 years, so I do know the basics of racing itself. It's getting the XJ to launch and most of all CUT A GOOD LIGHT thats the problem. Here's where I'm at so far.
I took it out for the first time yesterday. THe first run was to shake off the jitters and see how it would behave. I launched it like if you were leaving your parents house after a sunday dinner. Nice and smooth with no wheels up. Shallow staged just at the first lighting of the stage bulb. launch rpm and shift points, don't ask cuzz i wasn't paying attention withy everything else going on!
The oil light started blinking at second gear so i spent more time staring at that then the tach. I've added an oil cooler to the bike
recently and it's needing more oil in the pan than before...
1st run-
reaction time .571 (.000 is perfect). oh ya, it's a pro tree
60' 2.250
330' 6.025
660' 9.387 @ 70.02
1000' 12.41
1/4 15.04 @ 84.1
weather was 66 degrees, 44% humidity bp 29.24 with a headwind of 10mph.
Man that was fun!!!! Next run will be more serious.
Run 2-
Added 1 pint oil. launch rpm 5000 easing out on the clutch. shift rpm 9000. Nice smooth launch, front wheel comes up about a foot i'd guess.
R/T .462
60' 2.16
330' 5.824
660' 9.103 @ 71.26
1000' 12.07
1/4 14.62 @ 87.42
weather 74 degrees, 33% humidity, BP 29.52, 10 mph headwind. THis was a nice run all things considered. It felt good except that terrible reaction time. At least it's getting better...
Run 3-
I'm going to deep stage this run and try and kill the light. End result, deep staging works better for me, dumping the clutch doesn't. The front end came up and the bike tried to stall once it was up.
R/T .255
60' 3.05
330' 6.794
660' 10.0 @ 74.19
1000' 12.86
1/4 15.32 @ 90.64
weather- 68 degrees, 30% humidity, BP 29.68 and NO WIND.
Eliminations-
Did I mention this is a points race and I'm the only bike out there without wheelie bars etc.? No pressure there. First time racing a bike and going for it on a points day. LOL!!! Well, i tried not to let that get to me, or the fact that I was racing against the track champion. But of course the spectical of it all caught up with me rolling into the beams. I forgot to deepstage untill we were both staged. I ended up trying to nail it to make up for this. Result, the bike stalled in mid wheelie! That sucked! I did get it restarted quickly, but the race was long over by then...
R/T .335
60' 4.08
330' 7.745
660' 10.99 @ 73.74
1000' 14.03 by now i'm just sitting up straight with no race left in me. One hand on the throttle and the other slapping my leg for being a bonehead!
the 1/4 ended at 16.67 @ 84.4
Any ideas on how to get this thing to launch without wanting to stall if the clutch is dumped? Or is it a case of me needing to have a better touch on the clutch. I really need good lights to compete with the "pro's" on track points race days.
Oh ya, I guess I should give a rundown of the bike itself.
A naked 82 XJ1100 with 33k on the odometer. It has a fresh clutch, with barnett frictions and the old steel's. Also has the barnett springs. The tranny is also "fresh" from doing the second gear fix. That was a move the washer and use a new gear. Front forks were set on "4" with 12 psi and rears were "2" with 26psi in them. Uni pod air filters and stock exhaust. Rider weighs about 265lbs.
I don't want to add wheelie bars and all the race only things. I'd like to ride to the track, race and hopefully ride back home!
ANY TIP'S, IDEA'S, OR INSIGHTS APRECIATED!!!! Thanks-Tom.
1st run-
60' 2.250
330' 6.025
660' 9.387 @ 70.02
1000' 12.41
1/4 15.04 @ 84.1
Run 2-
R/T .462
60' 2.16
330' 5.824
660' 9.103 @ 71.26
1000' 12.07
1/4 14.62 @ 87.42
Run 3-
R/T .255
60' 3.05
330' 6.794
660' 10.0 @ 74.19
1000' 12.86
1/4 15.32 @ 90.64
Eliminations-
R/T .335
60' 4.08
330' 7.745
660' 10.99 @ 73.74
