xs11 plugs, and wires
  • 90spectrum
    • Jan 2006
    • 3
    • canton ohio
    i have looked on some of the sites to buy parts , i need to know what are the correct plugs and i cannot find plug wires for less the 30 per. is that about right? where can i find the parts i need? is there a site for basicly one stop shopping?
    Scott Heaston
    Re: xs11 plugs, and wires
    The wire pairs are part of the coil. Check out the plug caps also because they do go bad.
      Hey Spectrum,
      MikesXs.com has plug wires and plug caps at very reasonable prices. As Skids said, the wires don't come out of the OEM coils, unless you are doing the new wires in old coils repair.
      Also check out this Tech Tip on the types of plugs you can use:
      Spark Plug types tip
      Spark Plug High Tension Wires
      Spark Plug High Tension Wires- Original Type - Copper core with Black silicone
      rubber casing (1 Pr.).
      Part #23-2902 $4.00 USD /Pr.
      NGK Resistor Spark Plug Cap (5K Ohms)
      NGK Resistor Spark Plug Cap (5K Ohms). This Factory Original XS650 type
      can be used with All electronic ignitions (spark plugs with threaded stud type
      terminal end).
      Part #23-3113 $3.00 USD EA.
        Plugging along!
        Found another source, Dennis Kirk:
        Spark Plug Wire
        Dennis Kirk Part #: 2021
        Manufacturer Part #: 011141
        Spark Plug Wire
        Part Number - (Price)
        2021 - ($2.95)
        Quantity:
        10+ on Hand
        Alternate & Larger Images : Spark Plug Wire
        Overview Specs Fitment Images Sizing Send to Friend Warranty Hypalon-covered 7mm spark plug wire with a 19-strand tinned copper core
        Use wherever plug wire is replaceable (some are molded into the coil)
        Sold in 72 inch lengths
        • 90spectrum
          • Jan 2006
          • 3
          • canton ohio
          thanks guys
          Scott Heaston
