So I just got my H back after a blown engine last August. After a lot of around town cruising, I finially took it on a longer ride, just down to Kenosha (About a 45 minute freeway ride.) Since this stretch of freeway connects Milwaukee and Chicago, while the posted limit is 65, the actual speeds are closer to 80.
The bike seemed to run fine, until I exited. When I put my left foot down, it was like stepping on a oil slick. Looking down, and the pavement was dry, my boot was covered.
Great, I thought, another engine, and I just got this one.
But the bike was running fine, smooth, and so I pulled into the next gas station, wiped off the oil, added some more (The window was still empty, even after sitting a bit), and restarted the bike.
Oil started leaking from this dark bolt on the bottom of the engine;
Now, I am thinking this is one of those bolts that holds the bottom of the engine on. I am hoping you guys can tell me that I just have to pull out that one bolt, replace a crush washer or rubber seal or something (Even better if that something is available at a hardware store, rather than having to wait on a shop to get it in), put the bolt back in and be good to go.
I don't want to hear anything about pulling out the engine again. But it that what has to happen...?
I have a longer trip planned in a couple weeks, and if this leaking persists, with the other xs still under repair (Electrical gremlins. Don't you hate those), I might have to take the (sigh).....beemer.
HELP!!!!!
HELP!!!!!
