I took the wheels off and brought them to the shop to have new tires and tubes put on and to check the bearings. At that time I tried to wiggle things around and everything felt tight. I believe the fender was actually holding it tight enough for what I was checking at that time (2 months ago now). It wasn't until I took off the fairing and the everything else that I found the fork pinch bolts loose. I know to check those with a wrench in the future!
(I guess I should use the right name for the pinch bolts... thanks for the sublte hints. )
