i want to paint my engine, but i've read on the internet that the engine can overheat because it is now covered with an insulator. I'm hoping a thin layer of high temp paint won't make a big difference. any thoughts?
Will the engine overheat if i paint it?
Thin is the key word. Lay it on thick and will be an insulator. Flat black will actually cool better then bare aluminum by a little.
Steve80 XS1100G Standard - YammerHammer
73 Yamaha DT3 - DirtyHairy
CZ 400 MX'er
68 Ducati Scrambler
RC Planes and Helis -
Yes the engine will overheat. You should give me your bike and save yourself a lot of troublePat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
"Ja, dat's a hot von" (Swedish accent)
Sure... so what's the thickness of a layer of paint film? .001? Now if you slather on a thick coat of enamel... like with using a roller, you may have something, there.
Engine enamels, like a nice Chevy Orange lay on rather thick, but then my truck's engine is water cooled.
(My two XS850's have both been painted with that high temp black wrinkle paint. Maybe the extra wrinkles, by increasing the surface area, actually help dissapate the heat. And don't forget the that the engine will run cooler now because of how "cool" it looks)
(bogus scientific opinion)but i've read on the internet that...
Real men hang around in Motorcycle Forums, like this one. This is where the real experience and knowledge is. This site is staffed with brilliant people who...
Oooh! Gotta run... Sponge Bob is almost on!"Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
(Argueing with someone on the Internet is like running in the Special Olympics. Even if you win, you're still retarded)
Paint your Wagon, boat, bike, whatever!
Hey there MPCluever,
You may not have noticed but Yamaha put out a model called the Midnight Special, and it was painted totally black, entire engine!! The fins provide the radiating and cooling effect, a few mils of paint ain't gonna make much of a difference, go for it!!!
T.C.T. C. Gresham
I painted mine when I had it apart to do the big bore. I had the engine entirely apart, and baked the painted pieces in the oven @ 200 degrees for an hour as per the directions on the can. I used VHT brand, black engine paint. The oil does a large amount of cooling of the top end, so keep the level up. My oven wasn't large enough to hold the crankcase halves, so I rigged up a space heater, and suspended the case halves above it for a couple of hours. It has held up well in the almost two years since I did it. It does have a few rock chips in it, but that's to be expected. I didn't use any primer, just had a good, clean surface to start with. I do use an oil cooler, as it can get kinda warm here in Texas in the summer, but I haven't had any overheating problems. I didn't get much riding in last summer, as both the bike and I were both pretty banged up. Look at the pics that are posted in the webshots address below. You can see the engine before and after the paint work.Last edited by John; 02-26-2006, 05:32 PM.Comment
I painted my FJ engine gold with a high temp engine paint (VHT) and filed down the edges of the fins (I don't know if that made any difference or not). It's been running fine to this point.
Good luck and post pics whn you get it finished!81 SH Something Special
79 SF MEAUQABEAUXS
81SH Nor'eas tah (Old Red)
80 LG Black Magic
78 E Standard Practice
James 3:17
“Alis Volat Propriis”
Yamaha XS 1100 Classic
For those on FBComment
Engine paint removale tip
Depending on the type and brand of paint you use, gasoline, Brakleen and carb cleaner sprays make good "Accidental" paint removers. Degrease your engine after painting using Simple Green, or some other non- paint eatin' cleaner. (Had the leaking carb/air box syndrome do a number on a black wrinkle-coat painted engine case)"Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
I have had a sticking float to the 'fill the airbox' thing on mine not too long ago, but it didn't damage the paint at all. I don't know if was the brand of paint that I used or if it was because I baked the paint on to the parts, but there was no paint damage at all. Maybe I just got lucky.Comment
Seems to me that just running the engine will "bake the paint".
I painted the cases, cylinder, and head on my 400cc Honda Hawk when I lived in Arizona. Raced it there too. Used VHT brand engine paint and never had a problem with the paint or overheating.
Just change the oil regularly (I change mine every 3,000 or twice a year, whichever comes first) and keep the oil level up.
I'm feeling encouraged to mask-off my MNS and repaint the engine (it's faded to grey). Someone in the past painted the valve cover wrinkle black. Wrinkle looks good but all the tiny nooks and crannies hold dust and dirt. The motor will be flat black and the covers will be gloss black.Pat Kelly
Re: "Ja, dat's a hot von" (Swedish accent)
[/B]
I'm looking into buying this product called "Flitz." Says it can clean and polish aluminum easily and quickly.
gregGone but never Forgotten:
1980 XS11SG - "Scorpion"
Current:
2006 Yamaha FJR1300A - "Orion"
2007 Honda CBR600RR - "Twitch"
"Life is not a journey to the grave, with the intention of arriving safely in a pretty and well preserved body; but rather to skid on broadside, thoroughly used up, totally worn out and loudly proclaiming:
WOW - What a ride!Comment
Back in the late 1970's factory Honda motocross bikes engines were painter red. The Honda Techs claim that it dissipated the heat better than non painted engines. I don't think the temperature difference would be noticeable."We are often so caught up in our destination that we forget to appreciate the journey." "Comment
